Sülzer differenzial
Sülzer differenzial
Beitragvon Rabbit 16v » Donnerstag 24. März 2016, 23:40
Hallo zusammen, Ich bin aus USA. Ich habe zwei Lt 4x4. Ich habe eine problem mit mein Sülzer. Die diff hinten ist kaput. Ich suche für eine crown und eine pinion. Teile nummer: 919.04.701.04
My German is very poor and I have attempted my best. My apologies if it is incorrect. Thank you everyone for reading and maybe someone can help? I can post pictures if that is useful. Veilen danke!
Chris
Rabbit 16v
Fahrzeug: LT40 4x4 x2, LT45 4x4, LT28 Florida
Re: Sülzer differenzial
Beitragvon Waldfahrer » Freitag 25. März 2016, 08:18
Hi Chris,
unfortunately, I have no idea, if the Sülzer pinion and crown wheel is the same as in the stock-VW 4x4 ( 291525143M).
The latter is still available at VW-Classic parts, but for around 1700 $ :roll:
I will forward your question to our sister-forum, there are some Sülzer drivers more: http://www.lt-forum.de/forum/messages/202887.htm
Josef
Beitragvon Rabbit 16v » Freitag 25. März 2016, 19:01
Thank you so much, Josef! Unfortunately, the Sülzer set is not the same as the 291 VW stuff. Its Sülzer proprietary. I just read the thread relating to this where you posted on the other site. Do I need to sign up there as well to post in that thread?
My Sülzer is not with Dana axles unfortunately. It has the Hurth axles :(
Rabbit 16v
Beitragvon Waldfahrer » Samstag 26. März 2016, 10:04
Hi Chris,
Rabbit 16v hat geschrieben: Do I need to sign up there as well to post
no, you can post without any registration, only click to the "Senf" button (put one's oar in, if I translate correct ;-) ) below the statement, you wish to answer!
Then you have only to fill in your Nick on top and write your comment in the form.
Finally click the "Und ab damit" Button. Caution: It is not possible to edit your comment after sending!
Back to your problem: Maybe it would help if you disassemble the diff and make a dimensioned sketch of the faulty parts?! I forgot to say, that the part number you stated before, is not a VW part number, rather a hurth number.
Last chance would be thinking about alternative axles?! I think you have broader technological possibilities in the States than we have in Europe. We have very restrictive approval laws here.
Josef
Beitragvon Rabbit 16v » Samstag 26. März 2016, 19:48
Good to know. I might need to go over there and post as well.
I have taken it all apart for now. I think I may have sourced the part through the VW LT 4x4 page on Facebook. We shall see though. He is going to send it to me and once I have it I will be able to tell if it will work. Otherwise I will be searching again!
I do know its not a VW part number. I wish it was! That would make things a lot easier!
I thought about changing to Dana axles, but that is a lot of work and I intend to sell this LT once the other one has the TDI swap completed. Sometimes I do envy your TÜV. Sometimes I do not ;) Some of the cars on the road here are very scary. I work on them for a living and so I see some things that would make you scared to be on the same road.
Thanks again for the help!
Chris
Rabbit 16v
Beitragvon MCBKat4x4 » Sonntag 27. März 2016, 00:05
:doppel_top:
MCBKat4x4
Beitragvon Rabbit 16v » Sonntag 27. März 2016, 02:43
Oh hi! Lol! :doppel_top:
Rabbit 16v
Beitragvon Rabbit 16v » Mittwoch 20. April 2016, 20:51
Hallo zusammen. I am the person that was looking for the drive set. I managed to get one from Stefan. But now, I need technical information. Does anyone happen to know pinion bearing preload specification? Also carrier bearing preload specification? And lastly, torque specification for the bolts that secure the ring gear (crown gear) to the differential?
Thanks for any help!
gruß
chris
Rabbit 16v
